[Geoserver-devel] [jira] Created: (GEOS-1075) Investigate previews with multiple maps
                 Key: GEOS-1075
                 URL: http://jira.codehaus.org/browse/GEOS-1075
             Project: GeoServer
          Issue Type: Sub-task
    Affects Versions: 1.5.0
            Reporter: Chris Holmes
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 1.5.1, 1.6.0-beta1
This isn't high priority, but if there's a bit of extra time it could be cool if our preview page wasn't just a bunch of single maps, but instead you could click on a link and get a single map, but could also just put check-boxes by the maps that you want to see, and then the WMS reflector would make an ajax map out of all the layers. I suppose it would have to default to epsg:4326, or else figure out if all the maps were in an alternate CRS (though the wms reflector behavior now is to default to 4326 unless specified otherwise - that may be worth revisiting).
