[Geoserver-devel] [jira] Created: (GEOS-108) If no schema.xml file is present then no attributeTypes appear
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-108
Here is an overview of the issue:
        Key: GEOS-108
    Summary: If no schema.xml file is present then no attributeTypes appear
       Type: Bug
     Status: Open
   Priority: Blocker
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             Configuration
             WFS
   Fix Fors:
             1.2-beta
   Versions:
             1.2-beta
   Assignee: Jody Garnett
   Reporter: Chris Holmes
    Created: Fri, 5 Mar 2004 10:12 PM
    Updated: Fri, 5 Mar 2004 10:12 PM
Description:
I'm going to try to tackle this today, but I may have to run, so I'm putting it up on jira. But from my end it looks like if no schema.xml file is specified then no attributes make it into the FeatureTypeInfo. This is manifesting itself in two places for me right now - DescribeFeatureType has no attributes, and GetFeatureType specifying a specific attribute messes up because there are no attributes to compare against (I was originally testing to make sure the Date bug worked right now, and ran across these errors).
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
