[Geoserver-devel] [jira] Created: (GEOS-1080) KML Multiple Points
KML Multiple Points
                 Key: GEOS-1080
                 URL: http://jira.codehaus.org/browse/GEOS-1080
             Project: GeoServer
          Issue Type: Bug
          Components: Google Earth KML Output
    Affects Versions: 1.5.0
         Environment: Debian Linux
            Reporter: Michael Frumin
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: kml-bug.png
bug report for KML generation:
- make a layer that is a bunch of PointSymbolizers
- export it as a KML file.
look, for each Document, to see that there are 2 <Point>'s, eg:
<MultiGeometry>
<Point><coordinates>-73.9063115654528,40.6521443024159,NaN</coordinates></Point>
<Point xmlns:gml="http://www.opengis.net/gml&quot;&gt;&lt;coordinates
xmlns:gml="http://www.opengis.net/gml&quot; decimal="." cs="," ts="
">-73.90631157,40.6521443</coordinates></Point>
</MultiGeometry>
(nominal whitespace formatting is mine, would it kill ya to put some
newlines in there?)
having 2 <Point> elements right on top of each other results in, using
GEarth 4.x, 2 copies of the labl and having to disambiguate between 2
markers regardless of how zoomed in you are, eg:
http://www.nabble.com/file/8262/kml-bug.png
