[Geoserver-devel] [jira] Created: (GEOS-1081) kmattr and kmscore do not make it past the kml reflector
                 Key: GEOS-1081
                 URL: http://jira.codehaus.org/browse/GEOS-1081
             Project: GeoServer
          Issue Type: Bug
          Components: Google Earth KML Output
    Affects Versions: 1.5.0
            Reporter: Brent Owens
            Assignee: Brent Owens
             Fix For: 1.5.x, 1.6.0
If you try to specify the kmscore or kmattr values in the kml reflect URL, they will be ignored by the reflector and default values will be set.
Fix it to read the supplied values.
