[Geoserver-devel] [jira] Created: (GEOS-1096) valid GetFeature request returns NullPointerException
                 Key: GEOS-1096
                 URL: http://jira.codehaus.org/browse/GEOS-1096
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.5.0
            Reporter: Bart Maerten
            Assignee: Andrea Aime
         Attachments: erroneous_response.xml, GetFeature.xml
Unpack geoserver and start it up with the default setup.
Send a request for a feature through the XML POST method. Use a different prefix for the namespace of the feature type.
The result is a service exception.
Seems like namespace handling only works when using the same prefix name as server side configuration.
