[Geoserver-devel] [jira] Created: (GEOS-110) maven test fails for gmldatasource preventing full build
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-110
Here is an overview of the issue:
        Key: GEOS-110
    Summary: maven test fails for gmldatasource preventing full build
       Type: Bug
     Status: Open
   Priority: Minor
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             Configuration
   Versions:
             1.2-beta
   Assignee: Chris Holmes
   Reporter: Andy Kriger
    Created: Sun, 7 Mar 2004 12:02 AM
    Updated: Sun, 7 Mar 2004 12:02 AM
Environment: Cygwin on Win2KPro
Description:
It appears that ProducerTest is dependent on xalan but xalan is not listed as a dependency in Maven, so ProducerTest fails. Because the test fails, the gmldatasource install fails. Many other modules are dependent on gmldatasource so they fail to install as well. As a workaround, ProducerTest can be removed and gmldatasource will install successfully.
cd $GEOTOOLS_HOME/geotools-src/gmldatasource
maven test
[junit] Running org.geotools.gml.ProducerTest
[junit] Tests run: 7, Failures: 0, Errors: 7, Time elapsed: 1.984 sec
[junit] [ERROR] TEST org.geotools.gml.ProducerTest FAILED
cd target/test-reports
less TEST-org.geotools.gml.ProducerTest.txt
Testcase: testProducer took 1.125 sec
        Caused an ERROR
Provider org.apache.xalan.processor.TransformerFactoryImpl not found
javax.xml.transform.TransformerFactoryConfigurationError: Provider org.apache.xalan.processor.TransformerFactoryImpl not found
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
