[Geoserver-devel] [jira] Created: (GEOS-1107) Improper handling of lost database connection
                 Key: GEOS-1107
                 URL: http://jira.codehaus.org/browse/GEOS-1107
             Project: GeoServer
          Issue Type: Bug
          Components: PostGIS
    Affects Versions: 1.4.1
         Environment: GeoServer 1.4.1
O.S.: Windows Server 2003 with SP1
Web Server: IIS
Servlet Container: Jetty
PostgreSQL/PostGIS 8.0.x database backend on Linux RHE 4.0
            Reporter: Steve Marshall
            Assignee: Andrea Aime
             Fix For: 1.5.2
GeoServer does not properly handle a lost connection to a PostgreSQL/PostGIS database. GeoServer does not detect if the connection goes bad until after it has executed a failed query. The error handling seems to get GeoServer back in the proper state, but at a cost: the query that caused the error handling logic to execute returns as a failure.
To test this error, you can do any thing that will cause a database connection to go bad, then check the error return from a WFS query that uses this database connection. The error message will look something like this:
    500 Server closed connection without sending any data back
Suggestions for causing the connection to go bad include:
1. Keep the connection idle until the TCP keepalive feature closes the connection. For default system and PostgreSQL configurations, this will take about 2 hours 12 minutes.
2. kill the postgres backend process associated with the GeoServer application. Use the PostgreSQL system view pg_stat_activity to determine which backend is associated with the GeoServer application based on DB user id and the client host IP address.
More details on a case that revealed this error can be found in this GeoServer user group link:
http://www.nabble.com/null-value-in-log-file-tf3680605.html#a10789565
