[Geoserver-devel] [jira] Created: (GEOS-1115) factor in map preview functionality into the reflector
                 Key: GEOS-1115
                 URL: http://jira.codehaus.org/browse/GEOS-1115
             Project: GeoServer
          Issue Type: Improvement
          Components: WMS
            Reporter: Justin Deoliveira
            Assignee: Justin Deoliveira
             Fix For: 1.5.2
currently the map preview uses the bounds of the layer to supplement a wms request with a "good" bbox parameter, the kml reflector uses hte max lat lon extent which usually looks crappy. Make the reflector use the preview logic and then just have the preview call the reflector.
