class to xml schema type mapping is flawed
Key: GEOS-1122
URL: http://jira.codehaus.org/browse/GEOS-1122
Project: GeoServer
Issue Type: Bug
Reporter: Justin Deoliveira
Assignee: Justin Deoliveira
Fix For: 1.6.x
when the mapping from class to xml schema type occurs, geoserver uses type profiles to perform the mapping. The mapping is a bit lax in that matches to superclasses are also allowed. The algorihtm to lookup should be modified so that exact match is performed first, and if fails resorts to super class matching.
