[Geoserver-devel] [jira] Created: (GEOS-1123) Oracle / MapInfo Polylines rendered as polygon - vendor extension to prevent this behaviour required
                 Key: GEOS-1123
                 URL: http://jira.codehaus.org/browse/GEOS-1123
             Project: GeoServer
          Issue Type: Improvement
          Components: Oracle, WMS
    Affects Versions: 1.5.0
            Reporter: Tom Dean
            Assignee: Andrea Aime
            Priority: Minor
Currently Geoserver renders polylines as polygons if a fill is specified in the .sld For MapInfo and Oracle based maps this can be problematic since multiple geometry types can be stored in the same table and they should only be filled if they are in fact a polygon. Polylines should not be filled at all. Can an extension be provided to WMS to override the default behaviour?
For more details see: http://www.nabble.com/Rendering-Oracle-Polylines-as-polygon--tf3851592.html#a10946766
