[Geoserver-devel] [jira] Created: (GEOS-1126) Have a way to specify if the CRS declared is a "reproject to" or a "force"one
                 Key: GEOS-1126
                 URL: http://jira.codehaus.org/browse/GEOS-1126
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.5.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Blocker
             Fix For: 1.5.2
We are seeing multiple users that do have a native projection that does not match any EPSG code, and are having troubles because of the current behaviour (that does reproject instead of force). Yet, we also know of users that would need a reproject instead (that was the default coverages behaviour before I tried to harmonize things).
We need a way for the user to see the native WKT, and two radio buttons to be enabled if the two CRS do not match, allowing either to force the declared CRS, or to reproject towards it.
