[Geoserver-devel] [jira] Created: (GEOS-1128) Storing changes to the FeatureType Editor fails
                 Key: GEOS-1128
                 URL: http://jira.codehaus.org/browse/GEOS-1128
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.5.1
         Environment: GeoServer 1.5.1 running under MS Windows and Tomcat 5.0 with Java 1.5
            Reporter: Christoph Koschmieder
            Assignee: Andrea Aime
When editing an existing FeatureType (eg states) and either hitting the "change"-button next to the base schema list, or submitting the changes on this FeatureType give me an error:
HTTP 500 - Internal Server Error is displayed because Page ...config/data/typeEditorSubmit.do could not be found!
The same action performed with GeoServer 1.5.0 succeeds without an error.
