Class cast exceptions with PostPreProcessFilterSplittingVisitor
Key: GEOS-1155
URL: http://jira.codehaus.org/browse/GEOS-1155
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.5.1
Reporter: Chris Holmes
Assignee: Andrea Aime
Priority: Blocker
Fix For: 1.5.2, 1.6.0-beta1
Ok, I had this issue before, but didn't report it since I didn't have time to make a test case, and it didn't seem to pop up in major situations.
But it appears to be a major regression, since Like filters for one don't seem to work at all. This means that our geographical search example on sigma.openplans.org no longer works.
This is the request to http://sigma.openplans.org:8080/geoserver/wfs (if you want to try it I can turn on verbose error reporting to show the stack traces)
<wfs:GetFeature service="WFS" version="1.0.0"
outputFormat="GML2"
xmlns:topp="http://www.openplans.org/topp"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<wfs:Query typeName="topp:gnis_pop">
<ogc:Filter>
<ogc:PropertyIsLike wildCard="*" singleChar="." escape="\">
<ogc:PropertyName>topp:full_name_lc</ogc:PropertyName>
<ogc:Literal>seattle*</ogc:Literal>
</ogc:PropertyIsLike>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
The relevant stack trace is:
Caused by: java.lang.ClassCastException: org.geotools.filter.AttributeExpressionImpl
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.getFilterPre(PostPreProcessFilterSplittingVisitor.java:125)
at org.geotools.data.jdbc.DefaultSQLBuilder.splitFilter(DefaultSQLBuilder.java:153)
at org.geotools.data.jdbc.DefaultSQLBuilder.getPostQueryFilter(DefaultSQLBuilder.java:114)
at org.geotools.data.postgis.PostgisFeatureStore.bounds(PostgisFeatureStore.java:881)
at org.geotools.data.postgis.PostgisFeatureStore.getBounds(PostgisFeatureStore.java:864)
at org.geotools.data.DefaultFeatureResults.getBounds(DefaultFeatureResults.java:207)
at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.getBounds(ForceCoordinateSystemFeatureResults.java:130)
at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:407)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:625)
I also had problems with CQL filters when I was doing logical Filters (ANDs and ORs). So these may have a problem too. Example is:
http://sigma.openplans.org:8080/geoserver/wfs?service=WFS&request=GetFeature&typename=poly_landmarks&CQL_FILTER=cfcc%20<D82%20AND%20NOT%20DISJOINT(the_geom,LINESTRING(-73.99051%2040.4039,-73.96132%2040.67060))
Andrea, Saul said he'd look in to these if I could provide test cases, but my dev environment isn't set up for such things. Could you make test cases for AND filters and for LIKE filters?
