Bounding box is null (unknown) when geometry field isn't queried
Key: GEOS-1165
URL: http://jira.codehaus.org/browse/GEOS-1165
Project: GeoServer
Issue Type: Improvement
Components: WFS
Affects Versions: 1.5.1
Environment: Windows, PostGIS / Oracle
Reporter: Frank Steggink
Assignee: Andrea Aime
Priority: Minor
When a GetFeature is executed, with only a subset of the properties, and the geometry property isn't one of them, Geoserver returns a null bounding box (value "unknown"). This only happens when "generate feature bounds" is checked.
Examples:
Request 1 (without geometry):
<wfs:GetFeature service="WFS" version="1.0.0"
outputFormat="GML2"
xmlns:topp="http://www.openplans.org/topp"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd"
maxFeatures="1">
<wfs:Query typeName="pgtest:single_polygon">
<ogc:PropertyName>pgtest:prop_varchar10</ogc:PropertyName>
</wfs:Query>
</wfs:GetFeature>
Result:
<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs" xmlns:pgtest="http://www.example.org/pgtest" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.example.org/pgtest http://127.0.0.1:8080/geoserver/wfs/DescribeFeatureType?typeName=pgtest:single_polygon http://www.opengis.net/wfs http://127.0.0.1:8080/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd">
<gml:boundedBy>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#28992">
<gml:coordinates decimal="." cs="," ts=" ">6886.52587891,487230.53125 79645.1171875,558165.875</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<pgtest:single_polygon fid="single_polygon.37">
<gml:boundedBy>
<gml:null>unknown</gml:null>
</gml:boundedBy>
<pgtest:prop_varchar10>na</pgtest:prop_varchar10>
</pgtest:single_polygon>
</gml:featureMember>
</wfs:FeatureCollection>
Request 2 (with geometry):
outputFormat="GML2"
maxFeatures="1">
<ogc:PropertyName>pgtest:the_geom</ogc:PropertyName>
</wfs:Query>
</wfs:GetFeature>
Result:
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<gml:boundedBy>
<gml:coordinates decimal="." cs="," ts=" ">6886.526026,511453.2371 17210.88503,548799.4415</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<pgtest:the_geom>
<gml:Polygon srsName="http://www.opengis.net/gml/srs/epsg.xml#28992">
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates decimal="." cs="," ts=" ">17210.88503,511453.2371 6886.526026,511453.2371 6886.526026,548799.4415 17210.88503,547972.3647 17210.88503,511453.2371</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</pgtest:the_geom>
