[Geoserver-devel] [jira] Created: (GEOS-1174) Make sure proper charset encoding is used reading xml config files as well as when publishing files with FilePublisher
                 Key: GEOS-1174
                 URL: http://jira.codehaus.org/browse/GEOS-1174
             Project: GeoServer
          Issue Type: Improvement
          Components: Configuration, Global
    Affects Versions: 1.5.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.5.2, 1.6.0-beta1
We can't read properly utf8 configuration files on windows, and we assume utf8 encoding in the filepublisher.
We should try to guess the encoding instead
