Admin password with ampersand (or other special XML characters) breaks deploy
Key: GEOS-1183
URL: http://jira.codehaus.org/browse/GEOS-1183
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.5.1
Environment: Red Hat Linux Enterprise 3, Tomcat 5.5.23
Reporter: Ryan Hofschneider
Assignee: Andrea Aime
Priority: Minor
If you change the admin password using /config/loginEdit.do the password gets saved to geoserver/data/services.xml without properly encoding the password for XML.
This means that if the password contains any special XML characters (e.g., ampersand, less-than, etc.) and the application server is restarted, the app server will not be able to deploy Geoserver, as Geoserver fails with the following error messages:
[Fatal Error] :61:24: The entity name must immediately follow the '&' in the entity reference.
29 Jun 22:08:16 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'applicationState' defined in URL [file:/home/hofschnr/tomcat/webapps/geose
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'data' defined in URL [jar:file:/home/hofschnr/tomcat/webapps/geoserver/WEB
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'config' defined in URL [jar:file:/home/hofschnr/tomcat/webapps/geoserver/W
java.lang.RuntimeException: Error reading : java.io.FileReader@anonymised.com
at org.geoserver.util.ReaderUtils.parse(ReaderUtils.java:72)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadServices(XMLConfigReader.java:221)
at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:187)
at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:153)
at org.vfny.geoserver.global.Config.setApplicationContext(Config.java:69)
<snip>
