[Geoserver-devel] [jira] Created: (GEOS-1191) Pattern fills do not align properly in tiled maps
                 Key: GEOS-1191
                 URL: http://jira.codehaus.org/browse/GEOS-1191
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.5.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.5.3, 1.6.0
         Attachments: treesAlignmentIssue.png
Fill polygons with a graphics pattern, like the forest theme in the wms cite tests. Then use a tiled preview, and you'll see the patters gets cut at tile boders. Offsets should be adjusted somehow so that the pattern is drawn seamlessly.
