KML output breaks if source SRS is null
Key: GEOS-1192
URL: http://jira.codehaus.org/browse/GEOS-1192
Project: GeoServer
Issue Type: Improvement
Components: WMS
Affects Versions: 1.5.1
Reporter: Andrea Aime
Assignee: Justin Deoliveira
A user reported the following stack trace:
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:108)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:496)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:582)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:315)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:199)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:282)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:767)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:697)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:889)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:130)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:105)
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:106)
... 31 more
Caused by: java.lang.RuntimeException: java.lang.IllegalArgumentException: Argument "sourceCRS" should not be null.
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:146)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:110)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:677)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:293)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:126)
... 33 more
Caused by: java.lang.IllegalArgumentException: Argument "sourceCRS" should not be null.
at org.geotools.referencing.operation.AbstractCoordinateOperationFactory.ensureNonNull(AbstractCoordinateOperationFactory.java:743)
at org.geotools.referencing.operation.DefaultCoordinateOperationFactory.createOperation(DefaultCoordinateOperationFactory.java:186)
at org.geotools.referencing.CRS.findMathTransform(CRS.java:147)
at org.geotools.data.crs.ReprojectFeatureResults.<init>(ReprojectFeatureResults.java:126)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.loadFeatureCollection(KMLTransformer.java:325)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:144)
... 38 more
The datastore should provide an SRS in fact, but if it does not, no reprojection should occur.
