KML generating from Oracle Datastore failes if source SRS is NULL
Key: GEOS-1196
URL: http://jira.codehaus.org/browse/GEOS-1196
Project: GeoServer
Issue Type: Improvement
Components: Google Earth KML Output
Affects Versions: 1.5.1
Environment: Oracle Spatial
Reporter: Ronald Woita
Assignee: Andrea Aime
KML generation breaks if source SRS is NULL.
GeoServer should use the SRS value from FeatureTyp config section to reproject the data, if the origin SRS information from datasource is empty
