min Idle param in PostGIS has slightly unexpected behavior
Key: GEOS-1209
URL: http://jira.codehaus.org/browse/GEOS-1209
Project: GeoServer
Issue Type: Bug
Components: PostGIS
Reporter: Chris Holmes
Assignee: Andrea Aime
Priority: Minor
Setting the minIdle param in PostGIS actually sets the maxIdle param in DBCP, so it becomes the maximum number of idle connections it will allow. Thus if you're idle for awhile the number slowly drops to zero idle connections. It should probably just set the minIdle param in DBCP, I think in this class:
http://svn.geotools.org/geotools/trunk/gt/modules/library/jdbc/src/main/java/org/geotools/data/jdbc/datasource/DataSourceUtil.java
