[Geoserver-devel] [jira] Created: (GEOS-121) Build process
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-121
Here is an overview of the issue:
        Key: GEOS-121
    Summary: Build process
       Type: Improvement
     Status: Open
   Priority: Trivial
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
   Assignee: Chris Holmes
   Reporter: Pierrick Brihaye
    Created: Sun, 14 Mar 2004 7:00 AM
    Updated: Sun, 14 Mar 2004 7:00 AM
Environment: Tomcat 4.1.29/JDK 1.4.2_01/Windows 98
Description:
Currently, one needs Ant to be installed in order to build GeoServer.
The project could provide Ant librairies as well as bat/sh files.
Other point :
<!-- If you don't have your own conf directory uncomment on of the following -->
  <!-- <property name="test.type" value="UserBasic"/> -->
  <!--<property name="test.type" value="CitePostGis"/>-->
  <!--<property name="test.type" value="CiteShapeFiles"/>-->
a) fix the typo :slight_smile:
b) set UserBasic as default (given that Ant properties are "write once", an external file could override this default value).
Other point :
The build process creates build, data, server and conf directories. OK, the last 3 ones are cleand if everything is OK but I would put everything in the build directory which should be the only one to get write access.
The output files geoserver.jar and geoserver.war should IMHO also be build in the build directory
p.b.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
