Shapefile with thousands of points not entirely served by GeoServer
Key: GEOS-1218
URL: http://jira.codehaus.org/browse/GEOS-1218
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.5.1
Environment: Using OpenLayers to load the problematic GeoServer WMS layer. GeoServer 1.5.1 running over Debian Sarge.
Reporter: Alexandre Leroux
Assignee: Gabriel Roldán
Priority: Minor
Attachments: data.tar.gz
I have a shapefile with thousands of points served by GeoServer 1.5.1 (I know these should be included in a PostGIS database instead, but we're in prototyping phase ;-). The problem is the shapefile through WMS is missing half of the points (right hand side, so higher longitudes). However, if I zoom in the area where there's no points showed by GeoServer while there should be, the points are there.
Seems to me like GeoServer fails to load the entire shapefile when there is a very large number of points for a specific extent.
I joined a copy of the data to this bug report. This shapefile has no .prj (that's how it was given to me). There's 117,000 points in there. I specified the EPSG 4326 in GeoServer and it load at the right place in OpenLayers through WMS.
Thanks
