WMS test failure, WMTVER not recognized
Key: GEOS-1219
URL: http://jira.codehaus.org/browse/GEOS-1219
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.6.0-beta1
Reporter: Andrea Aime
Assignee: Andrea Aime
Priority: Blocker
Fix For: 1.6.0-rc1
Probably an issue with the dispatcher:
Test wms:wmsops-getmap-params-version-1 (s0013/w6ac25b3c31d325b1_1)
Assertion: When a GetMap request is made using WMTVER instead of VERSION, the response is valid.
Parameter VAR_WMS_VERSION:
Label: 1.1.1
Value: 1.1.1
Parameter VAR_LAKES:
Label: cite:Lakes
Value: cite:Lakes
Parameter VAR_IMAGE_FORMAT:
Label: application/pdf
Value: application/pdf
Parameter VAR_WMS_GET_MAP_HTTP_GET_URL:
Label: http://82.50.107.99:8080/geoserver/wms?SERVICE=WMS&
Value: http://82.50.107.99:8080/geoserver/wms?SERVICE=WMS&
Request w6ad237c15b1b1_1:
Method: get
URL: http://82.50.107.99:8080/geoserver/wms?SERVICE=WMS&&WiDtH=200&FoRmAt=application/pdf&LaYeRs=cite:Lakes&StYlEs=&BbOx=0,-0.0020,0.0040,0&ReQuEsT=GetMap&HeIgHt=100&SrS=EPSG:4326&WmTvEr=1.1.1
Response from parser parsers:HeadersParser:
<headers>
<header>
<value>HTTP/1.1 200 OK</value>
</header>
<header>
<name>Content-Type</name>
<value>application/vnd.ogc.se_xml; charset=UTF-8</value>
</header>
<header>
<name>Transfer-Encoding</name>
<value>chunked</value>
</header>
<header>
<name>Connection</name>
<value>keep-alive</value>
</header>
<header>
<name>Server</name>
<value>Jetty(6.0.2)</value>
</header>
</headers>
Result: Failed
