[Geoserver-devel] [jira] Created: (GEOS-1223) Do not force reprojection if no geometry properties are around
                 Key: GEOS-1223
                 URL: http://jira.codehaus.org/browse/GEOS-1223
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.5.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Critical
             Fix For: 1.5.2
Setup a data store so that the declared CRS is not equal to the native value (be it becuase it's missing, or because it's different), and then issue a WFS request that does not load any geomtric attribute. Currently the code throws an NPE exception:
Caused by: java.lang.NullPointerException
  at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.<init>(ForceCoordinateSystemFeatureResults.java:83)
  at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.<init>(ForceCoordinateSystemFeatureResults.java:73)
  at org.vfny.geoserver.global.GeoServerFeatureSource.getFeatures(GeoServerFeatureSource.java:288)
  at org.vfny.geoserver.wfs.responses.FeatureResponse.execute(FeatureResponse.java:305)
