Insert fails because of GML formatting
Key: GEOS-1229
URL: http://jira.codehaus.org/browse/GEOS-1229
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.6.0-beta2
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 1.6.0-rc1
The following insert fails:
{code}
<wfs:Transaction service="WFS" version="1.1.0" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:gml="http://www.opengis.net/gml" xmlns:sf="http://cite.opengeospatial.org/gmlsf"
xmlns:topp="http://www.openplans.org/topp">
<wfs:Insert handle="insert-1">
<topp:coastline gml:id="coastline.1">
<gml:boundedBy>
<gml:Envelope srsName="urn:x-ogc:def:crs:EPSG:6.11.2:3031">
<gml:lowerCorner>-2290659.02568378 2304522.61820067</gml:lowerCorner>
<gml:upperCorner>-2272982.7639574 2321608.0</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<topp:fnode_>1</topp:fnode_>
<topp:tnode_>1</topp:tnode_>
<topp:lpoly_>1</topp:lpoly_>
<topp:rpoly_>2</topp:rpoly_>
<topp:length>80887.979783424</topp:length>
<topp:coast10_>1</topp:coast10_>
<topp:coast10_id>527</topp:coast10_id>
<topp:cst10typ>22011</topp:cst10typ>
<topp:feature_ty>Coastline</topp:feature_ty>
<topp:certainty>Definite</topp:certainty>
<topp:certainty_>1029</topp:certainty_>
<topp:certain_01>2</topp:certain_01>
<topp:coast_a_01>1272</topp:coast_a_01>
<topp:coast_a_02>0</topp:coast_a_02>
<topp:the_geom>
<gml:Curve srsName="urn:x-ogc:def:crs:EPSG:6.11.2:3031">
<gml:segments>
<gml:LineStringSegment interpolation="linear">
<gml:posList>
-2277644.0 2321608.0 -2274007.63645483 2321571.6923812 -2272982.7639574
2321220.84983015 -2276779.98623007 2319215.26491011 -2277171.58919488
2318418.51097483 -2276869.95550597 2315246.85510884 -2277111.3653779
2314325.53125323 -2278411.25625211 2312697.17242218 -2282481.09266276
2308988.79440581 -2283267.18516939 2307790.20087065 -2282770.30095296
2307487.14196677 -2279205.05030396 2307224.88270065 -2279187.91893547
2306413.3606636 -2279772.48025827 2305240.20878574 -2280531.85416709
2304522.61820067 -2281245.10661702 2304756.20519295 -2283707.34931662
2306975.33057109 -2284427.89504062 2306804.13820872 -2285783.66409421
2305055.82094398 -2288042.20257383 2305269.55416915 -2290659.02568378
2306212.88604276 -2286657.81612991 2306355.4664049 -2285171.17239786
2307679.12845195 -2283972.63216661 2309571.76244501 -2283553.41561374
2311415.77896442 -2283945.37512669 2312281.39634474 -2287218.66746127
2315378.20389471 -2287080.47892666 2315585.9801674 -2282853.79404272
2314017.85557203 -2281862.62773486 2313806.71110972 -2281334.58136216
2314052.6078468 -2281702.2475802 2317295.64154046 -2279921.72380841 2318460.09948424
-2282486.5197332 2319934.52194548 -2282815.57450135 2321350.68858032
-2280776.94794276 2319445.48235311 -2279975.5856496 2319579.97088144 -2277644.0
2321608.0
</gml:posList>
</gml:LineStringSegment>
</gml:segments>
</gml:Curve>
</topp:the_geom>
<topp:dt>2007-07-02T12:06:37.671+02:00</topp:dt>
<topp:timetest>15:48:50</topp:timetest>
<topp:datetest>2007-07-03+00:00</topp:datetest>
</topp:coastline>
</wfs:Insert>
</wfs:Transaction>
{code}
This happens because Eclipse formatted the XML so that coordinates are split on separate lines and the parser apparently gets out empty elements out of the string split:
{code}
aused by: java.lang.RuntimeException: Parsing failed for null: java.lang.NumberFormatException: empty String
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:145)
at org.geotools.xml.impl.BindingWalker$BindingExecutionChain.execute(BindingWalker.java:197)
at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:163)
at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:167)
at org.geotools.xml.impl.ParseExecutor.preParse(ParseExecutor.java:259)
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:105)
... 57 more
Caused by: java.lang.NumberFormatException: empty String
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:994)
at java.lang.Double.valueOf(Double.java:447)
at java.lang.Double.<init>(Double.java:539)
at org.geotools.xs.bindings.XSDoubleBinding.parse(XSDoubleBinding.java:101)
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:131)
... 62 more
{code}
Reformatting the insert by removing the newlines make it work fine (after the xstimebinding bug is fixed, of course)
