Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-124
Here is an overview of the issue:
Key: GEOS-124
Summary: FeatureTypeEditor: SRS and Bounding box
Type: Bug
Status: Open
Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Versions:
1.2.0
Assignee: Chris Holmes
Reporter: Richard Gould
Created: Tue, 16 Mar 2004 4:27 PM
Updated: Tue, 16 Mar 2004 4:27 PM
Environment: Resin 3.x
Description:
SRS box reverts to previous saved/loaded number after a new SRS number has been entered and the Bonding Box button is clicked.
Reprojection/bounding box does not appear to work properly:
If Max Lat. number is changed, and the FeatureType submitted but NOT saved- opening it again in FeatureType Editor shows the new Max Lat number moved to the Min Long box and the Max Lat has reverted to original number it had before editing started the first time.
If Min Long number is changed and saved, etc, when FeatureType is opened in Editor- the number has moved to Min Lat box and Min Long box number has a different number in it.
Max Long overwritten by Max Lat number if the Submit button is pressed. and the feature type opened again in the editor
Pati
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
