Default text color for KML should be white
Key: GEOS-1275
URL: http://jira.codehaus.org/browse/GEOS-1275
Project: GeoServer
Issue Type: Improvement
Components: Google Earth KML Output
Affects Versions: 1.5.2
Reporter: Chris Holmes
Assignee: Justin Deoliveira
Fix For: 1.5.2a
Google earth labels look better when they're white, as that's how most of the labels are, and that seems to be their default. We should have more white labels. I think the key is that if there is a 'title' and an 'sld' we should just use white for the label, ignoring the SLD's label. If people just specify an SLD then I suppose we should use the color there. We should also include in the docs information on this, how you can use the 'title' to get your label white.
