Coverage configuration form allows pure SRS number to be inputed, but all of the code expects EPSG:XXXX instead
Key: GEOS-1286
URL: http://jira.codehaus.org/browse/GEOS-1286
Project: GeoServer
Issue Type: Bug
Components: WCS
Affects Versions: 1.6.0-beta2, 1.5.2
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.5.2a, 1.6.0-beta3
If you manually input the SRS code into the coverages configuration, you can input a pure number, but all of the code assumes the SRS is in the EPSG:xxx form, and starts misbehaving (preview and describe coverage do, don't know where else this assumption is). I'm going to change the code in the coverage config to check epsg is there (lower risk change than trying to figure out which places the code requires the "epsg" prefix to be there and fix them)
