Support use of proxyRedirectURL parameter in AceGI security and other spots
Key: GEOS-1288
URL: http://jira.codehaus.org/browse/GEOS-1288
Project: GeoServer
Issue Type: Bug
Components: UI
Affects Versions: 1.6.0-beta2
Reporter: Saul Farber
Assignee: Saul Farber
Fix For: 1.6.0-beta3
If you set the proxyRedirectURL parameter, then try to log in (using the awesome new AceGI security stuff) you wind up being redirected to the base url, not the proxyRedirectURL. This means you can't administer a geoserver box that is behind a proxy.
Also, the map preview link (on mapPreview.do) doesn't account for the proxyRedirectURL value correctly either, instead redirecting to the base url instead.
