SLD param in getMap only works when NamedLayer.Name matches specied layer name with prefix included
Key: GEOS-1298
URL: http://jira.codehaus.org/browse/GEOS-1298
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.5.3
Reporter: Justin Deoliveira
Assignee: Justin Deoliveira
Fix For: 1.5.4, 1.6.0-beta3
try using default_polygon.sld against states layer with the SLD paramter... it will not work unless you change the Name of the Name to topp:states. In the least it work without the prefix... and perhaps be smarter enough when there is only a single style in the sld to just use it.
