[Geoserver-devel] [jira] Created: (GEOS-1301) Support for multiple admins with specific access privileges
                 Key: GEOS-1301
                 URL: http://jira.codehaus.org/browse/GEOS-1301
             Project: GeoServer
          Issue Type: New Feature
          Components: Configuration
    Affects Versions: 1.5.3
            Reporter: Alexandre Leroux
            Assignee: Andrea Aime
            Priority: Minor
Are there plans to add multiple admins capabilities in GeoServer? The feature would be about multiple admin accounts with each its own access to certain data namespaces. The intended goal would be that some admins will not be able not mess with other admin's data configuration if they have not received the proper access rights.
Justin Deoliveira wrote:
>> I would say yes. A while back Andrea did some prototyping with a
>> security system called Ageci... which unless I am mistaken allows you to
>> configure access to pretty much anything you want. However it has not
>> been integrated into the user interface as of yet.
>> A better web user interface is something that we have been longing for
>> for quite some time. You can be assured that proper access control will
>> be built into it. But until that comes you are pretty much stuck with
>> the single admin user.
     [ http://jira.codehaus.org/browse/GEOS-1301?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Andrea Aime reopened GEOS-1301:
No, it's not possible. The request was for multiple admins having access each to a subset of the data. We don't have data related security control at the moment
                Key: GEOS-1301
            Project: GeoServer
           Priority: Minor
            Fix For: 1.6.0-RC1
