[Geoserver-devel] [jira] Created: (GEOS-1305) integrating fid as an id in KML Placemark
                 Key: GEOS-1305
                 URL: http://jira.codehaus.org/browse/GEOS-1305
             Project: GeoServer
          Issue Type: Improvement
          Components: Google Earth KML Output
    Affects Versions: 1.6.0-beta2, 1.5.3
         Environment: NA
            Reporter: gershwinou
            Assignee: Andrea Aime
To be able to trace any feature in kml transactions, it is needed to integrate the fid somehow in each placemark.
Proposed solution is to put as the id of the placemark (see http://code.google.com/apis/kml/documentation/kml_tags_21.html#placemark)
