Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-131
Here is an overview of the issue:
Key: GEOS-131
Summary: DescribeFeatureType request
Type: Bug
Status: Open
Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Components:
WFS
Versions:
1.2-beta
Assignee: Chris Holmes
Reporter: Miguel Ángel Esbrí Palomares
Created: Wed, 17 Mar 2004 11:13 AM
Updated: Wed, 17 Mar 2004 11:13 AM
Environment: geoserver 1.2 beta, os = winxp
Description:
when I make the following request:
http://picasso.dlsi.uji.es:8080/geoserver/wfs?request=DescribeFeatureType&typename=biz:zero
I get this:
<?xml version="1.0" encoding="UTF-8" ?>
- <xs:schema targetNamespace="http://www.bizkaia.net/geoserver" xmlns:biz="http://www.bizkaia.net/geoserver" xmlns:gml="http://www.opengis.net/gml" xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="1.0">
<xs:import namespace="http://www.opengis.net/gml" schemaLocation="gml/2.1.2/feature.xsd" />
- <xs:complexType xmlns:xs="http://www.w3.org/2001/XMLSchema" name="zero_Type">
- <xs:complexContent>
- <xs:extension base="gml:AbstractFeatureType">
- <xs:sequence>
<xs:element name="id" minOccurs="0" nillable="true" type="xs:long" />
<xs:element name="feattyp" minOccurs="0" nillable="true" type="xs:int" />
<xs:element name="frc" minOccurs="0" nillable="true" type="xs:int" />
<xs:element name="name" minOccurs="0" nillable="true" type="xs:string" />
<xs:element name="namelc" minOccurs="0" nillable="true" type="xs:string" />
<xs:element name="sol" minOccurs="0" nillable="true" type="xs:int" />
<xs:element name="routenum" minOccurs="0" nillable="true" type="xs:string" />
<xs:element name="the_geom" minOccurs="0" nillable="true" type="gml:MultiLineStringPropertyType" />
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:element name="zero" type="zero_Type" substitutionGroup="gml:_Feature" />
</xs:schema>
Then I try to validate the schema and get this error:
[Error] schema9054034.xsd:2:690: src-resolve: Cannot resolve the name 'gml:AbstractFeatureType' to a(n) 'type definition
' component.
[Error] schema9054034.xsd:2:3523: src-resolve.4.2: Error resolving component 'nw_Type'. It was detected that 'nw_Type' i
s in namespace 'http://www.w3.org/2001/XMLSchema’, but components from this namespace are not referenceable from schema
document 'file:/E:/programas/jakarta-tomcat-5.0.19/temp/schema9054034.xsd'. If this is the incorrect namespace, perhaps
the prefix of 'nw_Type' needs to be changed. If this is the correct namespace, then an appropriate 'import' tag should b
e added to 'file:/E:/programas/jakarta-tomcat-5.0.19/temp/schema9054034.xsd'.
So, I think that maybe something related to this:
the schema location be something like this file:........ /gml/2.1.2/feature.xsd or http://…??
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
