Freemarker templates are using the "default encoding" instead of UTF-8
Key: GEOS-1318
URL: http://jira.codehaus.org/browse/GEOS-1318
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.6.0-beta2, 1.5.3
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.5.4, 1.6.0-beta4
Freemarker templates need to know which encoding to use for output, and the writer passed to the template must be set to use a specific encoding, otherwise it'll just use the "default" one.
For OpenLayers template UTF-8 is needed, and I believe also for KML and GetFeatureInfo HTML output right?
