[Geoserver-devel] [jira] Created: (GEOS-1319) Halos don't seem to be properly centered on the primary label.
                 Key: GEOS-1319
                 URL: http://jira.codehaus.org/browse/GEOS-1319
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
         Environment: Geoserver 1.5.2, Windows XP Professional, PostgreSQL 8.2, OpenLayers 2.4,
            Reporter: Jason Horning
            Assignee: Andrea Aime
             Fix For: 1.5.x
         Attachments: screen.jpg
When using a polygon layer and labeling it with halos it appears as though the halos aren't properly positioned around the primary label. The halos all appear to be shifted slightly to the right on all labels. On some of the labels the vertical positioning is correct and on some of the labels the vertical positioning is incorrect.
