TextSymbolizer Graphic OnlineResource seems to lose accessibility to the graphic file.
Key: GEOS-1326
URL: http://jira.codehaus.org/browse/GEOS-1326
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.5.2
Environment: Windows XP Pro, PostgreSQL 8.2.4, PostGIS 1.2.1
Reporter: Jason Horning
Assignee: Andrea Aime
Priority: Minor
Attachments: basemap_roadsegments.sld
When using the Graphic element within the TextSymbolizer element the graphic will appear the first time that the SLD is loaded but will disappear on subsequent restarts of Geoserver. If I change the image's filename on disk and the filename in the SLD it will reappear but it will again disappear on subsequent restarts of Geoserver. In order to get the image to display I must continually switch the filename back and forth.
[ http://jira.codehaus.org/browse/GEOS-1326?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Jason Horning reopened GEOS-1326:
Issue not resolved after migrating to 1.6 nightly build on 10/17/07.
Key: GEOS-1326
Project: GeoServer
Issue Type: Bug
Components: WMS
Priority: Minor
Fix For: 1.5.4, 1.6.0-beta4
Attachments: bbsiroadsegments_default.sld, bbsiroadsegments_default_updated.sld, pointPng.sld
