[Geoserver-devel] [jira] Created: (GEOS-1334) Make GeoServer run in Oracle Application Server
                 Key: GEOS-1334
                 URL: http://jira.codehaus.org/browse/GEOS-1334
             Project: GeoServer
          Issue Type: Bug
          Components: Global
    Affects Versions: 1.6.0-beta2, 1.5.3
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 1.5.4, 1.6.0-beta4
Blaz Repnick provided these patches in order to make GeoServer run in Oracle Application Server:
{panel}
In srsList.jsp (at the bottom) you find this lines of script:
<bean:write property="<%= "srsIDList[" + idx + "]" %>" name="srsInfoForm"/>
<bean:write property="<%= "srsDefinitionList[" + idx + "]" %>" name="srsInfoForm"/></pre>
and this nested " are the source of the problem. the correct version is:
<bean:write property='<%= "srsIDList[" + idx + "]" %>' name="srsInfoForm"/>
<bean:write property='<%= "srsDefinitionList[" + idx + "]" %>' name="srsInfoForm"/></pre>
{panel}
and
{panel}
There's one more thing. In mainLayout.jsp there are lines that crash IAS/OC4J:
        GeoServer gs = (GeoServer) getServletContext().getAttribute(GeoServer.WEB_CONTAINER_KEY);
        String baseUrl = Requests.getBaseJspUrl(request, gs);
This is the fix. Works for all containers i tested:
     GeoServer gs = (GeoServer)getServletConfig().getServletContext().getAttribute(GeoServer.WEB_CONTAINER_KEY );
{panel}
