KML request + legend generation may trigger an exception
Key: GEOS-1359
URL: http://jira.codehaus.org/browse/GEOS-1359
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.5.3
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.5.4, 1.6.0-beta4
To reproduce setup the inet_weu layer from http://docs.codehaus.org/display/GEOSDOC/3+Google+Earth+customizations
and issue the request: http://localhost:8080/geoserver/wms/kml_reflect?layers=inet_weu&legend=true
The stack trace is:
{code}
java.lang.IllegalArgumentException: Argument "value" should not be null.
at org.geotools.util.SoftValueHashMap.ensureNotNull(SoftValueHashMap.jav
a:103)
at org.geotools.util.SoftValueHashMap.put(SoftValueHashMap.java:226)
at org.geotools.renderer.style.SLDStyleFactory.createStyle(SLDStyleFacto
ry.java:308)
at org.vfny.geoserver.wms.responses.DefaultRasterLegendProducer.produceL
egendGraphic(DefaultRasterLegendProducer.java:240)
at org.vfny.geoserver.wms.responses.GetLegendGraphicResponse.execute(Get
LegendGraphicResponse.java:81)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapte
r.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:585)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:19
1)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(
AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.ha
ndle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(Dispatch
erServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(Dispatche
rServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(Frame
workServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServl
et.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(Servlet
Handler.java:1054)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(F
ilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(Filt
erSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Fi
lterSecurityInterceptor.java:72)
ilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTra
nslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFil
ter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicPr
ocessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilte
r(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.jav
a:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.j
ava:98)
Handler.java:1045)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCha
racterEncodingFilter.java:108)
Handler.java:1045)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:3
58)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:2
31)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:6
29)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHand
lerCollection.java:149)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.
java:123)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:1
41)
at org.mortbay.jetty.Server.handle(Server.java:303)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:45
2)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpCo
nnection.java:721)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:509)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.ja
va:320)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool
.java:475)
{code}
