[Geoserver-devel] [jira] Created: (GEOS-1362) Data from postgis not rendered correctly
                 Key: GEOS-1362
                 URL: http://jira.codehaus.org/browse/GEOS-1362
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.0-beta3
         Environment: ( Tomcat 5.5, Java 5, 64 bit ) AND (Jetty / SVN Trunk, Java 6 , x86)
            Reporter: Arne Kepp
            Assignee: Andrea Aime
             Fix For: 1.6.0-beta4
         Attachments: expected.png, line2.sld, observed.png
SLD styles are not applied correctly when the data comes from Postgis.
For instance, I may want to create an outline effect by drawing street centerlines in as an 8px wide grey line on top of a 10 px wide green line. With data from Postgis, only the style listed first in the SLD file is applied. See the attached SLD.
I have tested this using railroads in NYC, retrieving the same data in a shapefile and in Postgis. I have also tested using the tiger_road style (without modification, the railroads also have a NAME string) with identical results.
I believe that text labels have the same problem.
