Editing shapefile results in locked layer
Key: GEOS-1389
URL: http://jira.codehaus.org/browse/GEOS-1389
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.5.3, 1.5.2, 1.5.1, 1.5.0
Reporter: Jody Garnett
Assignee: Andrea Aime
Origional email from Jesse Eichar:
{panel}
Hi list,
Have you gotten any reports of Geoserver 1.5.3 getting locked on a dataset after a few edits take place? Here's what I'm doing:
1. Add a geoserver layer (say tasmania roads).
2. Edit it a bunch of times (with uDig, any version as far as I can tell)
Eventually it will lock up (not uDig but rendering that layer). I can close the map and try to the the layer with a WMS. That will also never return (until uDig times out). All other layers are fine.
I kill GeoServer and it looks like it is deadlocking on the Shapefile Lock... Sounds like my fault or possibly a result of one of Andreas changes and I missed the mistake as well.
I think one of two things are happening:
1. The lock has an internal race condition and should be replaced with a Java 5 Read/Write lock
2. Some object is aquiring the lock (read or write I don't know right now) and forgetting to release it (or throwing an exception so that it doesn't get released).
{panel}
We tested every version of GeoServer; the latest version that works in GeoServer 1.4.1 (GeoServer 1.4.0 also works). To reproduce the problem we followed the uDig walkthrough 1 instructions:
# Add Tasmania lakes and Tasmania roads to a map in uDig
# Move a road
# Hit commit
After this first commit GeoServer is unable to draw the roads layer, if you shutdown GeoServer and restart the road will draw again (and you can see that the results of your edit were actually applied).
