[Geoserver-devel] [jira] Created: (GEOS-140) Use Avalon configuration objects
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-140
Here is an overview of the issue:
        Key: GEOS-140
    Summary: Use Avalon configuration objects
       Type: Improvement
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             Configuration
   Versions:
             1.2.1
   Assignee: Chris Holmes
   Reporter: Pierrick Brihaye
    Created: Tue, 6 Apr 2004 5:02 AM
    Updated: Tue, 6 Apr 2004 5:02 AM
Environment: NA
Description:
I think Geoserver's code could get a great benefit from Avalon configuration objects :
http://avalon.apache.org/excalibur/configuration/apidocs/index.html
Classes such as :
org.vfny.geoserver.global.xml.XMLConfigReader
org.vfny.geoserver.global.xml.XMLConfigWriter
org.vfny.geoserver.global.xml.ReaderUtils
org.vfny.geoserver.global.xml.WriterHelper
... would become useless and most of the :
org.vfny.geoserver.config.*
... classes could be efficiently refactored.
p.b.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
