[Geoserver-devel] [jira] Created: (GEOS-1401) Editing a SLD from Gentoo server with english locales provides wrong wrong characters on the specified encoding of the sld context.
                 Key: GEOS-1401
                 URL: http://jira.codehaus.org/browse/GEOS-1401
             Project: GeoServer
          Issue Type: Bug
          Components: UI
    Affects Versions: 1.6.0-beta3
         Environment: Linux server
            Reporter: Cédric Briançon
            Assignee: Andrea Aime
            Priority: Trivial
On a gentoo server for which locales are english, when I edit a style with french characters like "é" (e with an accent), I get a "?" character instead of the french characters.
However I've specified in the SLD context "<?xml version="1.0" encoding="ISO-8859-1"?>", the encoding character used is the default server locale.
A possible workaround may be to change the server system locale, but geoserver could probably try to display the edited sld in the specified encoding character chosen in the sld.
