ShapeZip output format should force the declared crs, and also handle the eventual lack of a prj file in the generated shapefile
Key: GEOS-1413
URL: http://jira.codehaus.org/browse/GEOS-1413
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.6.0-beta3, 1.5.3
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.5.4, 1.6.0-beta4
If the original data does not have a CRS set the shapezip output will fail with an exception due to the missing .prj file.
Moreover, the generate prj file reflects the original CRS instead of the declared one, this should be fixed as well.
