[Geoserver-devel] [jira] Created: (GEOS-1418) problem with DB2 in geoserver
                 Key: GEOS-1418
                 URL: http://jira.codehaus.org/browse/GEOS-1418
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.5.3
         Environment: WIndows
            Reporter: Valery Pellichero
            Assignee: Andrea Aime
            Priority: Critical
Hello,
I have a problem with a map who is in DB2
When I load the map, I have this error :
506062 [GRAVE] org.geotools.renderer.lite.StreamingRenderer - Could not parse WKT
org.geotools.data.DataSourceException: Could not parse WKT
        at org.geotools.data.jdbc.attributeio.WKTAttributeIO.read(WKTAttributeIO.java:82)
        at org.geotools.data.jdbc.QueryData.read(QueryData.java:184)
        at org.geotools.data.jdbc.JDBCFeatureReader.readFeature(JDBCFeatureReader.java:104)
        at org.geotools.data.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:85)
        at org.geotools.data.crs.ForceCoordinateSystemFeatureReader.next(ForceCoordinateSystemFeatureReader.java:141)
        at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1560)
        at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:711)
        at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:433)
        at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:238)
        at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:368)
        at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:516)
        at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:315)
        at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
        at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
        at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
        at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1050)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1041)
        at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
        at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
        at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
        at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
        at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
        at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
        at org.mortbay.jetty.Server.handle(Server.java:269)
        at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
        at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:687)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:492)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:199)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
        at org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:270)
        at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
Caused by: com.vividsolutions.jts.io.ParseException: Expected number but found ','
        at com.vividsolutions.jts.io.WKTReader.parseError(WKTReader.java:375)
        at com.vividsolutions.jts.io.WKTReader.getNextNumber(WKTReader.java:273)
        at com.vividsolutions.jts.io.WKTReader.getPreciseCoordinate(WKTReader.java:235)
        at com.vividsolutions.jts.io.WKTReader.getCoordinates(WKTReader.java:220)
        at com.vividsolutions.jts.io.WKTReader.readLineStringText(WKTReader.java:468)
        at com.vividsolutions.jts.io.WKTReader.readMultiLineStringText(WKTReader.java:566)
        at com.vividsolutions.jts.io.WKTReader.readGeometryTaggedText(WKTReader.java:426)
        at com.vividsolutions.jts.io.WKTReader.read(WKTReader.java:193)
        at com.vividsolutions.jts.io.WKTReader.read(WKTReader.java:162)
        at org.geotools.data.jdbc.attributeio.WKTAttributeIO.read(WKTAttributeIO.java:78)
        ... 40 more
506328 [INFO] org.vfny.geoserver.servlets.AbstractService - Service handled
The error caused by ',' in db2 but in db2 i dont have access at this number.
It's map of belgium and I chose UTF-8 for geoserver and for my DB
Can you help me??
Valéry
