[Geoserver-devel] [jira] Created: (GEOS-1428) Problem with SLD - External Graphics
                 Key: GEOS-1428
                 URL: http://jira.codehaus.org/browse/GEOS-1428
             Project: GeoServer
          Issue Type: Bug
          Components: Error Reporting
    Affects Versions: 1.5.3
         Environment: OS Linux CentOS, running Java 1.5 and GeoServer 1.5.3
            Reporter: Fernando Quadro
            Assignee: Chris Holmes
         Attachments: aves.zip
I am passing for a problem with SLD and would like to know if bug of the GeoServer is one. The situation is the following one, has a SLD (http://siaiacad09.univali.br/sld/publico/Aves.sld), where I use ExternalGraphics. Problem is that when makes it the call (GetLegendGraphics) in my WebGIS (MapBuilder), the legend is generated with problems, of the type, to change images, or exactly not to load some. It would like to know if some of you already passed therefore, is using version 1.5.3.
PS: The image in attach would have to be with all the icons in the legend (legend.png).
