Randomly problems with external graphics loading
Key: GEOS-1429
URL: http://jira.codehaus.org/browse/GEOS-1429
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.6.0-beta3
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.6.0-RC1
It has been a user report that under certain conditions (like high cpu or network load) the graphics symbolizers might get lost causing the generation of incomplete maps or incomplete legends. See related issues and also:
http://www.nabble.com/Problem-with-SLD---External-Graphics-tf4677688.html
This may due to the fact the external graphic loading code has a built in time out (see org.geotools.renderer.lite.ImageLoader).
Also, that class does not take into consideration issues with high volume external image loading and content changes (that is, same url but image changed).
The attached gt2 issue tries to consider alternatives to the usage of MediaTracker for image loading, as well as to address the other issues there.
