[Geoserver-devel] [jira] Created: (GEOS-1461) Workaround black raster generation in PDF
                 Key: GEOS-1461
                 URL: http://jira.codehaus.org/browse/GEOS-1461
             Project: GeoServer
          Issue Type: Improvement
          Components: WMS
    Affects Versions: 1.6.0-beta4
            Reporter: Andrea Aime
            Assignee: Simone Giannecchini
             Fix For: 1.6.0-RC1
Hi Simone. As you may know, rendering rasters onto pdf generates black images. I tracked down the issue to the following code in GridCoverageRenderer:
{code}
// Opacity
double opacity = SLD.opacity( symbolizer );
graphics.setComposite( AlphaComposite.getInstance( AlphaComposite.DST_IN ) );
Color c = new Color(0.0f, 0.0f, 0.0f, (float) opacity);
graphics.setColor(c);
graphics.fillRect(0, 0, this.destinationSize.width, this.destinationSize.height);
{code}
if I comment it out the image renders properly, apparenlty iText is not handling correctly DST_IN composition. Suggestions on how to workaround this?
Moreover, I'm not totally sure this code is fully correct. What if the graphics contained lower layers alredy rendered, wouldn't they be affected too by the above code?
