Investigate OGC geometric filteres breakage on postgis
Key: GEOS-1462
URL: http://jira.codehaus.org/browse/GEOS-1462
Project: GeoServer
Issue Type: Improvement
Components: PostGIS
Affects Versions: 1.6.0-beta2
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.6.0-RC1
From a user report:
GeoServer 1.6 beta 2 (and probably greater) on postgis at
least maybe other data stores, will not process ogc:Within,
ogc:Overlaps, filter operators etc correctly. Occasionally, it returns
SQL errors from postgis, but more usually returns an empty
feature collection.
I attach an example wfs query, which will probably get
filtered by the list, as well as a small sample point data set which
falls within that filter. Data is in EPSG:4326.
