[Geoserver-devel] [jira] Created: (GEOS-148) Test linux with resin (2.x and 3.x)
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-148
Here is an overview of the issue:
        Key: GEOS-148
    Summary: Test linux with resin (2.x and 3.x)
       Type: Test
     Status: Open
   Priority: Blocker
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
   Fix Fors:
             1.2.0
   Versions:
             1.2-beta
   Assignee: David Zwiers
   Reporter: Chris Holmes
    Created: Wed, 7 Apr 2004 12:05 AM
    Updated: Wed, 7 Apr 2004 12:05 AM
Description:
We need some solid resin testing on linux. I remembered a problem with the loading of datastores, at least on resin 2 and redhat. It would only ever recognize one at most, so be sure to test using oracle, postgis and shapefile in the same server.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
