[Geoserver-devel] [jira] Created: (GEOS-1482) Mock testing leaves temp directories behind, they eventually break the build on Windows
                 Key: GEOS-1482
                 URL: http://jira.codehaus.org/browse/GEOS-1482
             Project: GeoServer
          Issue Type: Bug
          Components: Global
    Affects Versions: 1.6.0-beta4
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.6.0
Building on windows leaves a ton of mockxxxxxx directories in the user temp directory (in my case {{C:\Documents and Settings\user\Impostazioni locali\Temp}}). Eventually they do break the build because the mock support is not able to clean them up anymore, but even without it, they are growing garbage in the temp directory (so it slows down all other apps anyways).
